My ae700 Review
Discussion in 'Projectors, Screens & Video Processors' started by phillfyspoon, Sep 30, 2004.
  1. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    Got it up and running through component froma sony ns930 dvd player.
    first impressions: first film was star wars epII, First off the image had alot of artifacts and grain but looked very "film like". I had the bulb on low with dynamic iris set to "on". I did some some tweaking with the settings on the projector and player and came up with a more natrual smooth image with less grain.
    Colour: Out of the box colours had a little blue and green push so I tweaked with the setting and after that colours looked bold and lifelike.
    Brightness: The bulb is certainly brighter then my old ae300 which I had on low. This gives the image more punch.
    Contrast: Bulb on low and dynamic iris on. This makes a big difference to contrast. switching between on and off there is a noticable difference to shadow detail. I was happy with my ae300's blacks just not overall shadow detail, but the ae700 has plenty of it in dark scenes. The image has more depth to it. Im very happy with the contrast and dont see myself wanting to upgrade because of it, like before.
    Screendoor: It is allmost invisable. I had to get my head 1-2ft to the screen the see the structure. Panasonic did good here.
    Verticle banding: Is still an issue with the panels used but can be tweaked to minimal effect. running the flicker tweak and turning off any picture processing from the dvd player makes it just noticable in bright or foggy scenes.
    Im pleased with the purchase and recommened this lcd highly. for the price it is a bargain. Colour and contrast have improved greatly over the other models.
    9/10
  2. nelius
    nelius
    Is that 3 points off for the VB issue? Is it really that distracting? I'm getting worried at this stage. I'm getting the impression that it's the worst in the series so far in regards to VB. This will be my first PJ so I've never seen VB before. I'm imagining something like seeing stripes when a blue sky scene is being displaye. Or like if you have a gradient colour when your screen is set to 16 bit colour. Please tell me it's not that bad. :confused:
  3. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    Very interesting with regards to VB,on my AE500 it was noticeable and I dont think I would consider upgrading to an AE700 fron the AE500 if the problem still exists.
    Doesn't really sound like the AE700 is going to be that "significant upgrade" us Panny users were hoping.
  4. eugdog2
    eugdog2
    can you tell what verticle banding is - I do not know :)
  5. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    It is thin vertical lines running from the top to the bottom of the screen. Most WXGA LCD Projectors seem to suffer from it to some degree, but it can be made less noticeable with tweaking..
    BTW, have you new AE700 users tried the Flicker Tweak ? Any less VB afterwards? :confused:
  6. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    it is quite bad very visable on a bright background, even on peoples faces!!
  7. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    phillfyspoon,
    Thanks for the review, sorry to read that VB is so evident.
    Fjorko,
    Which "flicker tweak" are you referring to ? If it's the tweak to reduce peek-a-boo scanlines, then that's a different issue to VB. DO you know of service menu tweaks for the AE700?
    Sean G.
  8. nelius
    nelius
    I'm not getting this VB thing. You say it's very visable on a bright background even on peoples' faces, but the first pic posted by zAndy1 (http://www.avforums.com/forums/showthread.php?p=1198422) shows Frodo close up with pale skin and yet there is no sign of VB. Another post in the thread gives an example of VB, giving evidence that a picture of VB can be taken meaning it should also show up on the pic of Frodo going by your comments. :confused:
  9. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    679
    +7
  10. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    I get mine tommorrow and have saved watching SW trilegy till I get it any sceens yuo recomend to see if i notice it?
    Will be running though a Harman Kardon 506 DVD into a IScan Proo, so computur in to PJ.
    All ideas wellcome
  11. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    I wouldnt say it was as bad as the ae500 pictures posted but not far off. Im using component progressive. Im trying to tweak it out but not much luck
  12. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,144
    41
    NW London
    +17
    is it as bad as the med picture in the zip file?
  13. nelius
    nelius
    Can we ask what DVD (Region) you were testing it with? Thanks for the info.
  14. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    I would say it might be on par with it if I was viewing that scene, im not sure Im trying to find a scene were it realy stands out. I have used ntsc and pal dvd's.
    Im using star wars epII and the two towers right now
  15. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    679
    +7
    Thanks for the quick reply Phillfyspoon. If its about half as bad, then its tolerable for me. I am going to be using my DVI output from my HTPC and later HDMI DVD Player, I hope this improves the picture, n hopefully there will be tweaks out to limit the Vertical banding to a tolerable level for most people, if not then its the Sony HS51.
  16. peve3
    peve3
    Aug 14, 2002
    438
    Does This PJ upconvert 1080P ? or does it not show it At all ?
  17. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    I am a little disapointed about the VB. I thought I wouldnt have to upgrade for along time with the ae700 but I will now if the VB gets sorted I properly will. apart from that a very good projector.
  18. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,144
    41
    NW London
    +17
    Still cant get over the fact that the image looks as bad as that picture in the zip file.
    I'll hope other people's reviews are less negative....
    lol no offence but perhaps you are super picky.... at least thats what im hoping to myself...
  19. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    Now imagine the Z3 has NO VB !!! Hahahaha!!! I would like to see those AE700 owners faces !!!! :laugh: :laugh: ( Meant in a nice way though!!! ) :D
  20. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    I too would like too see more reviews too see what they think. My ae300 was free of VB so im a little anoyed at these lines.
  21. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    Phill
    Did you try to tweak your new ae700 ?
  22. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,144
    41
    NW London
    +17
    What info is there about the Z3?
    Any information/prices/release date? The AVSforum doesnt seem too useful...
    I could be tempted to hold off the AE700 if this is coming soon. Damn you Fjorko putting ideas into my head, I was so set on this...
    lol
  23. andhoey
    andhoey
    Jul 23, 2004
    80
    9
    :censored: :censored: :censored: just when i thought things were sorted between sd;vb & rainbows i think i'll forget pj's and by a plasma ! can i return it to komplett before i ve even recieved it :suicide:
  24. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    I have tryed tweaking it is still there but im enjoying the projector now. I dont want to put anyone off the ae700 it still is a great projector, it's just the VB is still a Problem with LCD. The contrast is close to dlp and no screendoor, which are good points about this pj.
  25. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,144
    41
    NW London
    +17
    so with a bit of tweaking is it much better? I really couldnt stand the AE500 picture in the zip file and if it anything like that I cant cope with it....
    Does anybody know how much the Z3 will cost approx? ANd when it will be available?....
  26. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    Hey Ex
    My AE500 Picture isn't as bad as that picture......more like pic2 i would say ! :smashin:
  27. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,144
    41
    NW London
    +17
    Do you think it will have got worse in the AE700?
    I am really put off by phil's enourmous criticism of the VB....
  28. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    After watching a whole film without looking for picture problems, i thought the image overall was fantastic, the VB did pop up in the blue sky but I was sitting quite close to the screen about 7ft. I sat further back to around 10ft and it wasent noticable. I would like to see other peoples views on just how bad this problem is as I havent seen it on any other projector. And I am picky with my image I must admit.
  29. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,144
    41
    NW London
    +17
    good to hear, id be about 4m away on a 2m wide screen so do you think I will see it?
    I wont cancel my order for the moment, I now just need to sort out my brand new DRH screen that has chips on it and a wobble on the mounting....
    Thanks again
  30. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    You can make it even less obvious with a SLIGHT defocus, PLUS if your DVD has any Digital edge enhancement feature, TURN it off !! Makes the picture much better looking.
