My 885 Rattles!
Discussion in 'Home Cinema Control & Remote Controls' started by imilne, Jul 22, 2005.
  1. imilne
    imilne
    Oct 3, 2004
    524
    28
    +70
    Just received my 885 from CCL. Opened it up and... it rattles. As if something is loose and/or broken inside of it.
    I haven't actually charged it yet (struggling to get the blimming battery cover off to be honest), but does anyone else's make such a noise? If not, it's going back.
    Iain
  2. maclynn
    maclynn
    Feb 5, 2005
    41
    No rattle from mine, even though I dropped it on a tile floor.
    Mike.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    :rtfm: :rtfm: :rtfm:
    If you read the manual or the online FAQ you will relaise that the rattle is the tilt sensor that stops the LCD being on 24/7 (it lights up when you pick the remote up and look at the screen ie tilt it)
  4. imilne
    imilne
    Oct 3, 2004
    524
    28
    +70
    Well in my defence, the manual says bugger all about that, but you're right about the online faq. Although you only get to that once logged into the website, not as you're unpacking a shiny new toy that sounds broken.
    Good to know it's nothing to worry about though :)
    Iain
  5. maclynn
    maclynn
    Feb 5, 2005
    41
    Now you have got me worried as I have no rattle.
    Mike.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    as long as the tilt sensor works dont worry
  7. Anderzander
    Anderzander
    I struggled with the battery cover :mad:
    then my wife gently pressed down where it catches - and it popped open :eek:
    :oops: :oops:
