my 42pe50 doesn't take s-video so how can I watch sky+?
Discussion in 'Plasma TVs Forum' started by Not A Clue, Sep 10, 2005.
  1. Not A Clue
    Not A Clue
    Right, here's a conundrum for you...
    I've just purchased the sony db795 av receiver which is fine and will be picking up my Mission FS1 speakers & Panasonic 42PE50 up in a couple of weeks time.
    I want to connect Sky+ to my sony db795 and can do so through s-video.
    The problem I have is my plasma does not have an s-video input - only has component and scart - so how can I see sky+ :confused:
    btw my av receiver doesn't convert inputs to component as i understand it :(
    :suicide:
  2. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    check your manual to see if one of the scart sockets are s-video compatible.
  3. Not A Clue
    Not A Clue
    It says on the back of the 42pe50 (just checked in my magazine) s-video under a scart socket - so i think it must be?
    I thought s-video cables were round :confused: ?
  4. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    you need a s-video to scart adapter. Available any where.
  5. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    Just looked up your av amp.
    Personaly i would use a js-tec rgb(scart) to component converter into the av amp then to the screen. If you have a dvd player with component output you could send that to the amp too.
  6. Not A Clue
    Not A Clue
    Thanks mate for your help
    i read somewhere that sky+ isn't component in any way so you CANNOT convert it to component ? Does that sound right?
    Sorry for the additional qs - just trying to understand all this :lesson:
  7. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
  8. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    I've also looked up the spec of the amp on Sony's web site. It isn't hugely helpful. It appears that it only outputs s-video or composite - there is no mention of component so far as I could see, so Ukdan's suggestion of routing component via the receiver won't work.
    S-video leads are indeed usually the round plugs but s-video can also be sent via a scart socket provided the scart is suitably wired.
    Routing video via an av receiver is usually done to benefit from upconversion to component (which your Sony does't do), to simplify source changing (a learning remote will do it just as well), or to get on-screen menus from the receiver (a cheap s-video lead can be included to permit this even though it will not be the main connection method).
    That sounds confusing having read what I just wrote! What I am trying to say is that you may well be better off sending audio only via the receiver and routing all video direct to the plasma. The PE50 has at least one RGB enabled scart (I think), so forget converters, just get a decent scart lead and plug the Sky + direct into the plasma.
  9. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
  10. Not A Clue
    Not A Clue
    Hi Guys,
    Thanks for all your help. The sony website isn't great - I've checked the back of the amp and it does do component out (2 in, 1 out) so I guess I can either use a RGB scart > component, or s-video > scart to get around this problem.
    I just read elsewhere that the new sky+ box (the 160) does have component out (though I need to check for sure)...as I haven't yet got sky at the new address I'll check out the possibility of getting this which will also get me around my problem.
    Why isn't life ever simple ? :)
    Great people like yourselves do make it easier though :thumbsup:
  11. Not A Clue
    Not A Clue
  12. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You better tell this to Yamaha - my Yammie amp converts everything to component :)
  13. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    Nick whats the pq like when using the amp to upconvert s-video to component?
