i have a 360 - dated 17-02-06 and its very loud
my brothers 360 is no where near as loud
for instance my fans are louder than his, and i have the hitachi drive which is louder than his samsung.
the thing is my hitachi drive is even louder than any other
When i lie my 360 down the whole 360 seems to rattle and there is a low pitched sound which causes the floor to vibrate ever so slightly and it can even be heard in the room downstairs
AND thats on carpet !
The rattle and vibrations is not as loud however when its in the vertical position on carpet, but i am afraid it will overheat.
My 360 although it never has overheated gets very hot and i rarely play it for more than a few hours. Its not just when its not carpet either.
And i know its normal for it to get hot lol but my brothers 360 only ever gets warm
Apart from the loudness and heat however the 360 works fine and only rarely crashes.
At the same time though my brothers 360 isnt plain sailing as his samsung drive is scratching disks. And that is the second replacement for his previous 360 which had the samsung drive too and literally cracked our disks and decided to 'turn off' randomly
Anyway Does anyone else get the vibrations or rattles with their hitachi drive or is mine just faulty
