my 1st post,which player to get.
Discussion in 'Blu-ray & DVD Players & Recorders' started by cirdan, Sep 29, 2004.
  1. cirdan
    cirdan
    Sep 29, 2004
    230
    +3
    hi there. its my first post and im just after a bit of advice before i go to change my current dvd player.
    its a cambridge audio 57. ive had it for just under a year, and upto last week its been fine. but then i got the alien quad and ive had a few problems. mainly with lip sync and double cuts, dont know if thats the right term but explains what i got. so i took the player back to richer sounds who replaced it with another, incase the player was at fault. but the same problems were there. so i rang them up and they said it could be replaced for another make/model. so any advice on a replacement would be great. im going in on thursday. the new one would have to be around £120 max.
    thanks.
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,834
    London
    +1,094
    Welcome to the forums :smashin:
    Two models that come to mind in that price range are
    - Pioneer 575
    - Toshiba 340
    Neither of those should give you any problems.
  3. cirdan
    cirdan
    Sep 29, 2004
    230
    +3
    thanks for the reply.
    when i rang richer sounds i mentioned the pioneer, as i had seen it mentioned a few times with some good comments. but the guy said there had been a few problems with it on disks like the lord of the rings extended dvd's. is this true or was he maybe trying to put me off that brand/machine.
    ive had a toshiba a few years ago and was generally quite pleased with it, how good is the one you mention, noise, layer change etc.
    many thanks
  4. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    i've had the pioneer for a couple on months now and i've not noticed any problems with i've played disks from regions 1,2,3 and 4 without issue. and i think its better than the Tosh.
    Gary
  5. cirdan
    cirdan
    Sep 29, 2004
    230
    +3
    thanks. as i said ive had a toshiba before so would be keen to try a new machine, as long as its ok ofcourse. ill post back when i exchange my player.
    cheers.
  6. cirdan
    cirdan
    Sep 29, 2004
    230
    +3
    i got it changed today. no pioneers in so i thought id try the toshiba 530 which was around the cost of the player i was exchanging. i would rather have had a pioneer mainly because ive read so many good things, but as ive had a tosh before, my mum and dad currently use my old one and the alien disks work fine, i thought id give it a go, also i didnt want to wait indefinately until the pioneer came in.
    a few things ive noticed after a couple of films. first off the same problems i got with my alien set on the cambridge are still there which is very annoying, i may try and change the dvds again just incase. also there is a destinct sound whilst the player is playing, i know they make some noise but it was clearly evident throughout a film i watched before, it was a little offputting, i dont remember the cambridge doing that it was very quiet, could this be because its a new player and ive only had it on for a few hours?
    well i managed to borrow a pioneer 370 i think it is from a relative for a few days and the alien set works ok. so i think i will try to get a pioneer.
