phillsmit3
I have a new surround system for Christmas. It plays from USB, Bluray and also has optical input. (no HDMI input)
I am trying to connect my mxq box to it and my tv does not have pass through.
The MXQ box has a digital coaxial spdif socket but its a 3.5mm jack.
I have ordered this: Cable Mountain Digital SPDIF Coaxial to Optical TOSlink Signal Converter.
This will convert the digital coaxial signal to optical then I can use a normal optical cable to plug into the surround sound system.
The bit I am stuck with is this. I think I need some kind of Digital SPDIF 3.5mm jack to RCA cable but I can not seem to find this cable anywhere.
I assume i can not use a normal 3.5mm to phono as these are analogue?
