MX800RFS & MRF200 output?
Discussion in 'Home Cinema Control & Remote Controls' started by stevebez, Nov 11, 2004.
  1. stevebez
    stevebez
    Jul 11, 2004
    493
    +13
    Hi there...
    Is it possible to replace one of the MRF200's IR output flashers leads with a mono miniplug fitted cable to feed into a Xantech distribution block (eg 789-44)
    This would mean I could hide the MRF200 out of the way !!!
    Anyone tried this - or similar ?
    Rgds Steve
