MX700 or MX500 and Pioneer Hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by mutley, Feb 2, 2005.
  1. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    Did anyone succesfully hacked a Pioneer DVD Player to multiregion with an Universal Remote control like the MX700 or MX500?
    I've an MX700 and using prontoedit, i created a button and changed the IR signal to that one circulating the net (videohelp or even here at the forums) using copy paste.
    Saved the ccf file and then with the MXeditor i copied the ir code to a button in the MX700.
    Sent the code about 100 times but the player didn't shut down and isn't multiregion (Pioneer 470).
    Can't the MX700 hack the player? it should do as it accept ccf files...
    Maybe i'm missing something.
    :lease:
