mx440....or....FX 5600 256mb
derby4life
as the title says ..how much difference will i find between these two ... i currently have the basic geforce mx440...but can get the fx5600 256mb really cheap ....is it worth it ...is there much between them .....cheers :D
Tigerblade
Depends how cheap but I would imagine there would be a significant performance increase as the mx range are crippled feature wise. The MX is DX7, the FX is dx9 AFAIK and can run PS2.0 enabled games.
EDIT : Found a benchmark with both cards, albeit the FX is the 5600 Ultra. Basically showing the the 5600ultra is a Geforce 4 ti4200 with DX9 capabilities, which would be a large upgrade to your current card.......if the 5600 you can get is an ultra that is :)
http://www.anandtech.com/printarticle.aspx?i=1797
derby4life
thanks for the reply mate much appreciated....very very cheap :smashin: ....
derby4life
Tigerblade said:
I'd do it then :thumbsup:
Get to play Half Life 2 etc as they were meant to be seen :D
TBH hl2 played ok with the mx440 .....obviously not full spec but pretty good...I'm in the process of upgrading the whole lot but like everything it cost ££££
Similar threads
