MX-3000 for UK Sky Digibox
Discussion in 'Home Cinema Control & Remote Controls' started by cprendergast, May 5, 2005.
  1. cprendergast
    cprendergast
    I was wondering if anyone could direct me to where I could get the icons and codes for configuring my MX-3000 to control Sky UK Channels thru the standard Sky Digibox - is it out there ?
  2. cmo
    cmo
    Hi cprendergast,
    Make sure you've got the latest software and firmware as I believe the latest code database has the Sky codes, otherwise either learn them or rip them off a CCF (pronto file) , let me know if you need more info.
    As for the channels - I always use www.satlogo.com
    hope this helps,
    Chris.
  3. cprendergast
    cprendergast
    Hi Chris,
    I will try this - thank you so much for the info.
    Clem
