MVX250i Cannon Digital Camcorder how to transfer to DVD/CD
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by kdale19, Dec 17, 2004.
  1. kdale19
    kdale19
    HI, I have just bought a MVX250i Cannon Digital Camcorder. Would anyone be able to tell me how to transfer the video from the camera to a DVD/CD. I can do the "still" picture via USB but it is the actual video footage that I would like to transfer. The cables and equipment/software that is required if possible...basically everything that I need to get me going.
    Many thanks...Kdale19 :confused:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    Well as you have found out USB is not good for getting your footage onto the PC. To do this you need to connect the camcorder via firewire (aka iLink, ieee1394 or DV port). Do a search on this forum for 'firewire' and all you need to know to get started should be explained in the posts you find.
    Mark.
  3. kdale19
    kdale19
    Thanks for that, much appreciated for the info
