schizophonic
Established Member
I used tsMuxeR to convert my .mvks files to .m2ts as someone suggested.
It did a great job of muxing the files very quickly. I converted a lot of the files and stored them over to my NAS drive. Brought it over to my uncles PS3 *i dont own one* and got the PS3 to pick up the video files.
I tried on converted .m2ts file and it work perfectly with sound.
However some didn't seem to play any sound. Here are the details of the file:
And this is the one that did work.
On the PS3 - the sound goes into an AV reciever which should be able to handle all of those formats. It goes through via optical cable and the options on the PS3 is switch on
The picture works perfectly but sound doesn't on some files. I've changed the settings back to HDMI and that works file on all files.
Was it converted wrong? Doesn't the AV reciever accept A_DTS or the PS3 doesn't pick them up?
Code:
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 37mn
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 24 bits
Language : English
Code:
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 32mn
Bit rate : 640 Kbps
Language : English
