MVision V40-104 RF modulator Sound
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Guy 286, Apr 20, 2017.
Tags:
  1. Guy 286
    Guy 286
    Apr 20, 2017
    11
    London
    Hi I have a Vision V40-104 but I can't figure out how I change the sound settings Pal B,D,I etc can anyone please help??
  2. Nathan Cooke
    Nathan Cooke
    Oct 10, 2015
    132
    Isle of Wight
    +32
    What is a Vision V40-104? TV, STB or what?
    Sound settings Pal B,D,I etc refer to analogue broadcasts. There are no analogue broadcasts in Europe now except on some cable systems in Ireland, Germany, and possible elsewhere.
    If you are not on one of these it is not relevant.
  3. TJT1
    TJT1
    Jul 29, 2011
    4,139
    East Sussex, UK
    +903
    It appears that it's an RF modulator as per the thread title:) and Here but it seems that it's for analogue TV if that makes a difference. But it seems that it should work as it just requires a video and audio input.
  4. Rodders53
    Rodders53
    Dec 8, 2007
    4,703
    Lowestoft
    +807
    About - Vision Products Suggest you contact them for a copy of the manual. Current model is a 114, but manual not available online that I can see.
    Other than that, one Bill Wright of Wright's Aerials fame has been known to e-mail a photocopy to people via the uk.tech.digtal-tv newsgroup in the recent past; so asking there may get you one.
    My guess would be it is via a sub-menu accessed through the front channel setting up down buttons... press both together perhaps?
  5. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    23,684
    Redditch
    +4,010
    You need to look up the sound carrier frequency for the PAL system you want to use. From the spec
    Sound Sub-carrier Frequency: ±2.25MHz max. In 0.25MHz steps
    How you change the setting I have no idea.
  6. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    23,684
    Redditch
    +4,010
    It's just as relevant as the built in modulator in a sky-HD box. Connected to a composite video and analogue audio source it produces a PAL TV channel using the UHF carrier channel of your source (one that doesn't clash with the channels used by the local digital transmitter).
    Sound carrier frequencies from
    PAL - Wikipedia
    (B/G/H, I and D/K) use different sound carriers (5.5 MHz, 6.0 MHz 6.5 MHz respectively)
    It's output is simply tuned into using the legacy PAL tuning capability of any remote TV connected to the output. UK sourced TV's require the PAL I audio carrier (6.0MHz).
  7. Nathan Cooke
    Nathan Cooke
    Oct 10, 2015
    132
    Isle of Wight
    +32
    Have a look on this thread. It seems someone called Bill has the instructions who may copy them to you.
    Google Groups
  8. Guy 286
    Guy 286
    Apr 20, 2017
    11
    London
    thanks for the replies yes I want to change it to Pal I, there are two screw dials but they don't appear to make a difference so it could be a fault I don't know for sure unless someone can confirm how to change the sound types.
    Thanks again.
  9. Nathan Cooke
    Nathan Cooke
    Oct 10, 2015
    132
    Isle of Wight
    +32
  10. Rodders53
    Rodders53
    Dec 8, 2007
    4,703
    Lowestoft
    +807
    :thumbsup:Good find. I'd lay money on it being the same device re-badged. Wonder who actually makes it. ;)
    and I was right on how to access the setup by pressing + and - together :clap:
    NB Pal M & N require different colour subcarrier offsets as well as the sound carrier so the 'presets' it uses is sensible.
    @Guy 286 - the variable controls are signal level controls and are mentioned in the manual linked to; however without suitable test equipment it will be a suck it and see process to do. Maybe start with them 'in the middle', and work from there?
  11. Guy 286
    Guy 286
    Apr 20, 2017
    11
    London
    Thank you very much I really did try searching :)
    Now I have a confession :( mine is not made by vision its Mvision the reason I put Vision V40-104 is because if looks very similar and the Vision V40-104 seems more common
    but holding both buttons doesn't seem to work so I guess its either a fault or this Mvision one witch I believe is Italian is not cable of changing modes :(
    Thanks everyone :)
    Edit:If theres no objection can I change Thread title to Mvision and see if there is anymore info?
  12. Rodders53
    Rodders53
    Dec 8, 2007
    4,703
    Lowestoft
    +807
    Modulator VHF \/ UHF with display Mvision ????? This the one?
    Looks to be a Spanish design and may be PAL B/G only by design (as some sold here are suited for the UK's PAL-I format only).
    You could try asking the eBay seller / company above for a copy of the instruction booklet?
