Mux 2
Discussion in 'Satellite TV, Sky TV & FreeSat' started by boyler, Jan 27, 2003.
  1. boyler
    boyler
    Ever since ITV digital went into liquidation I have a problem with all the channels on MUX2 (ITV1, ITV2, Channel 4 etc), i.e., programs constantly breaking up, but all the channells on the other MUX's are fine. Does anyone have any thoughts on this.
  2. Fernsehman
    Fernsehman
    I believe that the transmission system was changed for some MUXs but not others. Anyway, it sounds as if you'll need a better aerial. Replacing your coax downlead might help if it's not already the correct double-shielded type without any breaks/joints or wall sockets.
    Downloading the latest software and re-running "store" might help.
    Fman
