MuVo N200 Folder change
Discussion in 'Headphones, Earphones & Portable Music' started by thejudge, Aug 1, 2005.
  1. thejudge
    thejudge
    Oct 28, 2002
    189
    19
    What is the correct method of changing the playback folder in a MuVo N200?
    I have the folders set up as follows:
    Root>Music>Artist>Album
    The player is fine but the supplied manaul.chm file on the disk leaves alot to be desired.
    At the moment whilst in music mode if i hold the scroll button down it changes to what looks like the folder skip screen. From this i can find the required folder/album but then i press the play button to access the folder. If i press the scroll button in to choose the folder i'm fairly sure this will skip the folder, which leads me to another point, how do you "unskip" a folder? (incase i skip one by accident!)
    The problem with this method is that it is all too easy to skip the folder as my thumb is already on the scroll button.
