Muting TV so sound comes only from amp
Discussion in 'TVs' started by Stampax, Dec 28, 2003.
  1. Stampax
    Stampax
    So finally got a home cinema set up - 5.1 and all that. All seems to be very nice to, with one issue. To turn off the sound of the TV so I only get sound from the speakers, my Sony TV needs to go through about 3 menus - kinda annoying. Even more annoying is that everytime the TV turns off, it resets itself, so you will have to go through these menues to turn the sound off every time I turn the TV on.
    Have I just got an annoying TV? Or is this common? Or am i being stupiud and missing something obvious?
    If I get one of those expensive remote controlls, can you teach it to do a serious of controls, so one touch will do the equivalent of going through all those menues?
  2. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    At the risk of sounding flipant, just use the rc to turn the volume down.
  3. Piya
    Piya
    Feb 6, 2002
    Leeds
    Yeh, I just have to turn the volume of my JVC tv down to get rid of the tv's own speaker sound. Muting button will show an annoying symbol on the screen of some tvs, not to mention the problem of resetting itself back on like yours.
    Regards
    Piya
  4. phenom2003
    phenom2003
    If you go into the menu and change the volume, then choose an option like store or save that volume should then be selected by default when you power on the TV.
    Rich
  5. taimur
    taimur
    Jan 9, 2003
    512
    19
    Glasgow
    you could use a SCART cable with only video connections, and no audio connections, going to your TV
  6. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Its the same with the 32fx68 that is to feed audio out through the tv phono you have to turn speakers off inthe menu you also have to then use the volume control to give input to your amp. Also all the tv sound settings can still influence the sound .Anyone know why Sony chose this method ?
