Muting on AV32R
Discussion in 'TAG McLaren Audio Owners' Forum' started by scarty16, Nov 28, 2003.
  1. scarty16
    scarty16
    Jul 1, 2003
    1,391
    +300
    I have a AV32R and when for example you change channel on TV the 32R mutes for a split second and of course you hear the click/click when it turns back on.
    Is there an option to stop it automatically muting?
    I am also fed up trying to explain the reasoning for it to my friends !
  2. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    You could switch off the "mute using relays" option, then you won't hear the clicking, and won't notice the mute.
  3. scarty16
    scarty16
    Jul 1, 2003
    1,391
    +300
    how do I do that as I have been looking throug hteh manual for ages to find it?
    Is it in the set up wiz I am using v3.75 on a SP box.
  4. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    It's not part of the "Setup Wizard" - yu'll have to go into the manual settings. Can't remember exactly where it is - it's called "Mute Configuration".
    If no one's posted I'll look when I get home.
  5. scarty16
    scarty16
    Jul 1, 2003
    1,391
    +300
    I know I set it up when I got the box as it seemed a good idea at the time but now it doesn't!! And I can't remember how to change the bloody thing back agian!!!grrrrrrr
  6. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    From your AV32 setup menu: -
    Change Setup
    Loudspeakers
    Mute Configuration
    Set "Mute using relays" to "No"
  7. scarty16
    scarty16
    Jul 1, 2003
    1,391
    +300
    Thanks for that, I was looking everywhere for it at the weekend and didn't even think of looking in there!!!
    I think I should stick to kit made by AIWA!
  8. Black 5
    Black 5
    Jul 19, 2000
    367
    19
    Isle of Man
    +3
    pronounced "AAAAGGGGGGGGHHHHHHHHHHHHHH!!!!!!!!!!!!"
