Mustek R100LB DVD recorder multiregion hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Steve Garry, Mar 18, 2005.
  1. Steve Garry
    Steve Garry
    Region Free and PAL type settings
    After much hassle with a machine that has the wrong PAL setting, I've got these for anyone that needs them.
    Ideally, before starting, do a reset to factory setting if the PAL code is wrong, to clear the database of stations
    Then
    At the blue DVD screen, with no disc in, and do it quickly, otherwise it times out.
    Press Return
    Press Info
    Press 8,8,8,x
    Where 0 = region free
    1-6 = region code
    7 = PVD on/off toggle
    8 = PAL setting. Puts another menu up that allows change between ( in my case ) PAL-B/G & PAL-I, which was the main hassle I had.
    9 = display, (not for long) settings that are enabled, and some revision/version data.
    Power off and on again on completion.
    After changing the PAL setting, you may have to do a complete rescan of the channels before it works.
    Hope this gets others out of trouble, I had an issue with the unit I got, it was factory set to PAL-BG, and I needed PAL-I for it to work here.
