Mustek PL408T portable
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by piggies, Aug 28, 2004.
  1. piggies
    piggies
    The PL408 player is not Multiregion by default. To activate this player as Multiregion please complete following instructions.
    · Turn on your player.
    · Close DVD disk door without a disk inserted.
    · Press the following sequence of keys on your remote
    control.
    · Press "SET-UP".
    · Press “Next” & then “Prev”.
    · Again press “Next” & then “Prev”.
    · Version 2 appears on top right hand corner of your TV
    screen (2 being your existing region code)
    · Change version (region) by pressing < button until 255
    appears (correct code for Multiregion).
    · Press "SET-UP" again & scroll down to exit.
    · Press " SET-UP " again.
    · Insert DVD disc and play.
    This worked for my unit bought in the UK. Have tried region 1,2,3 and 4 and discs I have recorded on my Panasonic DVD recorder from TV and satellite.
