Mustek PL408T hack anyone?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by piggies, Aug 27, 2004.
  1. piggies
    piggies
    Hi, just got one of these, believe it to be hackable, anyone got any ideas?
    Thanks.
    Found it and it is as follows.
    The PL408 player is not Multiregion by default. To activate this player as Multiregion please complete following instructions.
    · Turn on your player.
    · Close DVD disk door without a disk inserted.
    · Press the following sequence of keys on your remote
    control.
    · Press "SET-UP".
    · Press “Next” & then “Prev”.
    · Again press “Next” & then “Prev”.
    · Version 2 appears on top right hand corner of your TV
    screen (2 being your existing region code)
    · Change version (region) by pressing < button until 255
    appears (correct code for Multiregion).
    · Press "SET-UP" again & scroll down to exit.
    · Press " SET-UP " again.
    · Insert DVD disc and play.
    Worked for me but as ever at your own risk.
