Thanks for the responses guys and
@robotron for confirming. Really glad that you are also pleased with it!
@Ascotbilly you're right, you do simply have to scroll past them and it's not big issue - just not perfect!
Regarding the speakers, when you say "normal rules apply" that is what is confusing me, the myriad of rules!! I think I've got the basics nailed (W/ohms/sensitivity) but it's the nuances that get me.
Pic of the room below - excuse the messiness, there are three of us living/working/exercising here...
The speakers are/will be on either side of the tv. Distance from the tv to the sofa is only about 2.5m but the room itself is clearly a fair bit bigger. Ideal budget can stretch to say ~ £500, so a fair bit more than the Bronze 2 if it's worth it. I also don't plan on being here for longer than a few years so I don't want to buy the speakers just for this room, if that makes sense. I want them to be capable of a bigger room (if I move somewhere bigger!).
I'd want them to be adept at general use ie music and TV. I mostly listen to electronic music so decent bass response is a must but I really appreciate highs (as weird as that sounds) and I hate muddy sounding speakers so basically a good full range is important.
I've read loads of reviews and as I mentioned it just becomes overwhelming. A few times I have found a pair that seem great but the review mentions that "careful pairing is required" and my balloon gets deflated... because how do you do that!!
Another thing I'm concerned about is having a capable amp (which I think this is) and then pairing it with underwhelming speakers.
So any advice would be greatly appreciated... I'm new to this forum so if there's somewhere else I should be posting that you think would be able to get some more opinions please let me know.
Thanks very much. Ed
