Musical Fidelity X-Cans
Discussion in 'Headphones, Earphones & Portable Music' started by G a f f e r, Apr 9, 2005.
  1. G a f f e r
    G a f f e r
    Dec 31, 2003
    2,899
    U.K.
    +484
    Just bought one of these SET valve headamps in pristine condition for only £60 (little previous use). Unfortunately, no box or instructions. So I downloaded the paltry 2 pages from MF website, which gives very little info. Can anyone tell me what valves this uses? I assume it would be about 5-6 years old (being the first version) in which case, when do i replace the valves?
    Unlike my standard EL34 valve amp, I was told I should leave this one plugged in (switched on) all the time. Is this safe or will it overheat and reduce valve life? (Basic Q's, I know, but no answers on the MF website).
    Thanx for any help.
    PS Amp sounds Great at the mo, treble a bit grainy/high on some recordings...probably not helped by my Senny hd575 cans though.
    PPS and here it is: [​IMG]
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    I can't remember but I thought it was ECC88s, I will check. If it has hardly been used then they won't have worn out but can be improved (different thing). You can leave it on bu for headphone listening I would just turn on when needed. The valves are not stressed in this design.
  3. G a f f e r
    G a f f e r
    Dec 31, 2003
    2,899
    U.K.
    +484
    Thanx.
    You're right, the stock tubes are a type of ECC88 called 6922.
    I could also use 7308 or Cc tubes.
