Musical Fidelity A5 Amp / CD combo
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by barcrawler, Nov 27, 2004.
  1. barcrawler
    barcrawler
    Nov 27, 2004
    I have the opportunity to buy the above on a good deal (circa 30% off :D ) but wondered what your views might be.
    They are the new limited edition ones (links to both on homepage: http://www.musicalfidelity.com/mf/index.jsp)
    Plenty of power and v good quality, including valve outputs on CD (which I am led to believe is good - spot the noob! :hiya: )
    Anyway all opinions would be great!
    B :cool:
  2. barcrawler
    barcrawler
    Nov 27, 2004
    Just proved how much of a noob i am and didnt search, not to many good things to say about this.
    What do people think of Quad 909 / pre amp setup?
  3. 337GUS
    337GUS
    Nov 1, 2000
    630
    NE Scotland
    +18
    Hi there, looks like I'm following you round :)
    I haven't heard the A5's yet, hope to at xmas. According to MF they're better than the 308's for less cash. 30% seems like a cracking deal and if they are better than the 308 stuff then you're onto a winner. However from a few comments I've read they are not as good as MF say, anyway I won't be swapping my 308 system for them just yet :)
    If you are looking for alternatives to demo then have a listen a few very different sounding systems, suggest:
    Naim CD5x/112x/150x (try adding flatcaps/hicaps)
    Cyrus CD8x/PSX-R/8vs/PSX-R
    Arcan Diva / FMJ
    Rega Jupiter/Cursa/Exon/Exon (try some Rega speakers)
    Quad 99CD-P/909/909
    Gus
  4. recruit
    recruit
    Barcrawler i would have a listen to the Cyrus 8vs/PSX-R & CD8x/PSXR-R had mine for just over a week now and stunning Combination, there is so much more Dynamics & grip in my system now!!!!
    John :)
  5. bass007
    bass007
    Apr 8, 2004
    1,283
    london
    +34
    hey barcrawler, care to share where I could get 30% off? I am really interested in the CD player
  6. barcrawler
    barcrawler
    Nov 27, 2004
    Sorry dude, I know someone in the business and would do me a deal being a mate but cant pass this on. Sorry dude, if it were public domain I wouldnt hesitate in let you know.
    Heard a horror story about Cyrus and there customer support (or extreme lack of) so a little put off by them, will investigate other suggestions tho. Thanks all!
  7. barcrawler
    barcrawler
    Nov 27, 2004
    Naim tuff I liked at What hi-fi live BUT 50w from the power amp is not much at all and thinking about quad 22l speakers and this is not enough power imo.
    time to look at the rest :D
    EDIT: which is better range, DIVA or FMJ?
  8. recruit
    recruit
    Always had excellent Service from Cyrus and there new range is stunning don't be put off by 1 bad experience!
    John
  9. barcrawler
    barcrawler
    Nov 27, 2004
    hmmm arcam FMJ stuff looks good, any thoughts people?
  10. 337GUS
    337GUS
    Nov 1, 2000
    630
    NE Scotland
    +18
    Naim watts are different to other watts! :) :)
    Seriously, try to hear them and have a look here :
    http://pinkfishmedia.net/forum/forumdisplay.php?forumid=5
    http://naim-audio.infopop.net/1/OpenTopic?a=cfrm
    The FMJ range is best, CD33/A32 integrated.
    C30/P1 pre / power worth a look, heard it at a show and wasn't bowled over but may suit the 22L's.
    Cyrus info http://www.rdh.34sp.com/forums/
    Gus
  11. barcrawler
    barcrawler
    Nov 27, 2004
    Cheers again gus!
    I like the arcam stuff, but cant remember what is was I listened to >o(
    I keep hearing more and more names and its getting more and more confusing!!
  12. recruit
    recruit
    You need to demo all the products in you're set out budget and that should keep things nice and easy even though there maybe quite a few just listen to them and you will soon find what you like!
    John
  13. howesey
    howesey
    The A5 CD is ok, a bit too bright for my liking, it also has a bug where you need to turn the whole unit off as it crashes when you load a CD. The amp is damn plain awful - bright, sloppy bass, distorts at 12 O'clock and that isn't that loud, has a tinny sound to the upper mids. It has a smooth un-gritty sound but it's soundstage is bad. Vocals sound like your singing into a bottle. It's basically a A308 with cost cutting on various componants. It sounds like a cheap Marantz amp. You'll find it very hard to find cables and speakers to match the A5's.
    The 909 and 99pre is a good combo. Sounds good on most speakers and has a lot of power.
    I myself have both the A5's and Quad systems, I much prefer the Quad, just my opinion.
    Cyrus tend to break down, and when they do it's next to hard to get them repaired. Their customer services are bad. They sound decent enough though.
    Oh, and whoever is giving you the 30% off the A5's, they need their account closing. You're not allowed to give discount on MF equipment. MF enforce an RRP as they are classed as a Cottage Industry.
  14. barcrawler
    barcrawler
    Nov 27, 2004
    Well found out that was hot air anyway and just guessing, actually turns out he can do 15% of some ex demo stuff!!
    Anyway heard the x-series and going for that, love it!!!
  15. howesey
    howesey
    A5 which has been out for just over a month and ex-demo.
    Yeah, you can give discount on ex-demo as it's used.
  16. barcrawler
    barcrawler
    Nov 27, 2004
    yep, had two only want one.
