Music Videos
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by GrooveYard, Feb 5, 2009.
  1. GrooveYard
    GrooveYard
    Jan 29, 2009
    5
    Im looking to film music videos.
    Firstly for youtube and other websites but need to be good enough quality for tv broadcast.
    I'm looking at:
    Sony HVR-Z1E - £3300
    Sony HVR-Z5E - £2900
    Sony HVR-HD1000E - £1000
    Sony HDR-FX7 - £2400
    but also:
    Panasonic HDC-SD9EB-S HD Camcorder - £350
    Sony HDR-SR12E - £700
    obviously the prices are quite a wide range but i really need to know what cameras are good enough and if paying extra is going to make a huge difference. Sound is of no importance as all videos are edited and dubbed.
    Many thanks in advance.
    P
  2. A n d r e w
    A n d r e w
    Jun 25, 2008
    2,039
    Sydney
    +242
    The consumer camcorders you've listed (and indeed all other AVCHD camcorders) are not suitable for broadcast: regardless of resolution, the chroma subsampling employed is simply not up to spec (nor is the dynamic range, the signal to noise ratio, etc.) and the resulting video is likely to be rejected by any network you approach. Networks use specialised equipment to QC supplied materials - it might look good to your eye, but it won't to a vectorscope and waveform monitor.
  3. GrooveYard
    GrooveYard
    Jan 29, 2009
    5
    That's great thanks.
    So now i'm down to:
    Any advice?
    thanks
    P
  4. chrishull3
    chrishull3
    Aug 3, 2006
    4,024
    103
    Yeovil
    +282
    Owning a FX-7 AND SR-12 i can tell you with an external mike the SR-12 has every bit a pq sound and low light ability.
    A SR-12 USER August can confirm its ability on this page
    http://www.avsforum.com/avs-vb/showthread.php?t=1004811&page=93
    by the way the FX -7 can be bought for a lot less than you mention including
    http://bentonvillemall.co.uk/acatalog/Sony_FX7E.html simply electrics are even cheaper but enough said there, http://www.ciao.co.uk/Sony_HVR_HD1000E__6822464 this one is only a hc1 in a large shell.good luck with what ever you get.
  5. GrooveYard
    GrooveYard
    Jan 29, 2009
    5
    OK now I'm looking at:
    Sony HDR-FX7 - £1600
    Any thoughts?
    P
  6. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    Honestly,
    Get the Z1:D
    It is the " most likely to succeed" and is not the costliest for nothing
    It is not considered a consumer camera
  7. chrishull3
    chrishull3
    Aug 3, 2006
    4,024
    103
    Yeovil
    +282
    like to know why you think the 1 is better than the 5
    HVR-Z5 PAL* Sony HDV Camcorder HVR-Z5P , HVR-Z5E
    http://www.myshopping.com.au/SP--12831_Sony_HVR_Z1_Handycam_Video_Camera
    the z1 is admitedly a very good if you like these giants but generaly all i have read from z1 users moving to the z5 or even the fx100 [fx1000 admitedly prosumer] say the later outperform the z1 including low light.
  8. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    I dont think the Z1 is " better" as such .
    The Z1s ability to shoot NTSC and PAL( out of the box) and its use of CCD rather than CMOS seem to endear it more to the " Pros" other wise the Z5 is rather more " modern" and costs less
  9. chrishull3
    chrishull3
    Aug 3, 2006
    4,024
    103
    Yeovil
    +282
    Yes some like ccds sen also a lot prefer cmos for its better low light,new buyers seem to be drooling over this z5 i might have gotten one if it was not for the recession and the wifes adament she wont carry one around like she does my present ones:smashin:
  10. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    I just wish there were an HC 1 sized , Z5 .. best of both worlds!:cool:
  11. chrishull3
    chrishull3
    Aug 3, 2006
    4,024
    103
    Yeovil
    +282
    Dead right what i have always said:smashin:
  12. craga2k
    craga2k
    Feb 19, 2009
    where have you seen these prices? they are much more now
