Music in second room with Sony 1080
Discussion in 'AV Receivers & Amplifiers' started by jonancat, Jun 10, 2005.
Tags:
  1. jonancat
    jonancat
    Apr 11, 2005
    11
    I have a Sony STR-DB1080 A/V Receiver with 5.1 set-up in my lounge.
    I have two questions:-
    1. Am I right in thinking that if I connect up 2 speakers in the kitchen via the front speakers B terminal & select the A+B speaker setting on the receiver I can then listen to the same music in both the lounge & kitchen?
    2. I may be changing the receiver to the Arcam AVR300 later in the year (to go with the DV79 I recently bought), will the above work with the AVR300?
    Thanks.
  2. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    The AVR300 has support for a second zone so you could run cables to the kitchen and listen to a source from the 300 there.
    John
