Music DVD's- PAL/NTSC speed differences?
Discussion in 'Movie Forum' started by nathan_silly, Sep 29, 2003.
  1. nathan_silly
    nathan_silly
    Does the PAL & NTSC speed difference effect music DVD's?
    My brothers got some music DVD's I wish to buy- some filmed over here (ie The Corrs concert in the UK)- and some in the US (ie 93-99 Madonna collection)
    Would the The Corrs concert on Region 1 be 4% fast? since being converted from PAL to NTSC? (I'll be buying the NTSC version)- and the R2 is correct?
    And the 93-99 Collection be correct? (NTSC version)- wheras the R2 is fast?
    :confused:
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,844
    Somewhere in South Yorkshire
    +5,078
    Unlikely.
    Speed and pitch differences only arise when the original material was shot on 24fps film (as used for theatrical presentation of movies). They are NOT standards converted, usually. They are Telecine'd (converted from FILM to video) at different speeds for the two systems and it is the telecine process to PAL video that causes the PAL speedup - not standards conversion.
    Music videos are typically shot straight on to video (in either NTSC or PAL) and HAVE to be standards converted. Standards conversion does not change pitch or speed.
  3. nathan_silly
    nathan_silly
    Thanks for the info.
    What about digital movies?- such as Toy Story, Monsters Inc? I thought these would be easy to transfer from the digital master to PAL? Would all digital movies still have PAL speed up?
  4. LV426
    LV426
    Jul 14, 2000
    12,844
    +5,078
    Now that, I don't know. But, my suspicion is, that, even in the digital domain, material intended for transfer to film will be rendered at 24fps. And a PAL master of such material would retain its overall image quality best if it were transfered to PAL video at 25fps - hence I suspect it probably is speeded up. But I'm far from sure about this.
