Murphy's War DVD - which R2 version?
Discussion in 'Movie Forum' started by crobo, Aug 10, 2005.
  1. crobo
    crobo
    Mar 10, 2004
    3,116
    83
    +117
    This is a long shot but has anyone got a R2 copy of this they can comment on? I was planning to buy this from Play.com but they have 2 R2 versions - one for £3-99 with no technical info whatsoever, and a 2002 Anchor bay release for £6-99 with 5.1. You'd think this would be the logical choice but I read a review (DVD compare?) that said some of the swearing had been dubbed out and the picture quality was bad. Any info on either version greatly appreciated; I seem to remember this film from years ago as a good adaptation of a good book, with O'Toole at his best.
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    I don't know if either of the R2 versions are anamorphic widescreen or not, but I have the R1 version which definitely is. It's only in mono but it is perfectly acceptable, as is the picture quality.
    http://www.dvdpacific.com/item.asp?ID=54908
    Steve
  3. pabsjl
    pabsjl
    Feb 22, 2005
    73
    Basingstoke (European city of chav 2008)
    +9
    I pre-ordered the Anchor Bay version when it first came out.
    The opening titles are in widescreen, but then the picture zooms in as if it was on t.v. :mad:
    So I wouldn't bother with this version.
    pabsjl
    Paul B.
  4. crobo
    crobo
    Mar 10, 2004
    3,116
    83
    +117
    Hey thanks for that chaps. It's a jungle out there. I have never ordered from DVDpacific but I guess they are OK?
  5. stretcher
    stretcher
    Jun 25, 2002
    496
    Between Ashford (Kent) & Canterbury
    I give them the thumbs up - they're not necessarily the quickest, but they're reliable, cheap, and I'vre always found customer service very helpful and effective when they were needed. :smashin:
