multiswitch cable order problem.
Discussion in 'Satellite TV, Sky TV & FreeSat' started by wilkybobs, Feb 15, 2014.
  1. wilkybobs
    wilkybobs
    Mar 11, 2009
    346
    +3
    Hi.
    I have just bought a house which has a multiswitch, the problem I have after cocking up the order of cables I can't find the correct entry in the switch as its not marked well on the inputs..
    I have a friends meter so I know which cable from the dish is H/H H/L V/H & V/L so signal is there and good.
    The problem I have is that the multiswitch is foreign I think and has not the same markings and has no name on it. It was working well untill I changed the cracked Quattro. OOOPPS
    It has 14V Lo , 14V , 18V Lo ,18v
    This is exactly as it is marked up.
    The problem I have is that I have channels :
    BBC1 OK
    BBC2 OK
    ITV ( no signal on all ITv's)
    Ch4 OK
    Ch5 OK
    Sky News ( No signal)
    On $ky sub:
    Gold( no signal)
    Dave ( no signal)
    Comedy central ( No signal)
    possibly more channels off but Im sure if the cables were in the correct order on the switch it would be OK, I have tried moving them around but keep loosing others. But have had ITV at one stage then lost it when I placed anether cable into switch.
    The problem was I didn't mark the cables on the Quattro LNB and when I put in in the wrong order I cant sort it at the switch as markings arn't the same.
    What are the 14v and 18v and what is the lo, it doesn't state .
    How do I depict H/H and others into 14v or 18v
    Help much apprieciated.
    Regards
    WilkybobsLOW but lo
  2. hog
    hog
    Jan 15, 2005
    380
    28
    +36
    here yo go
    14v lo = v low
    18v lo = h low
    14v = v hi
    18v = h hi
  3. wilkybobs
    wilkybobs
    Mar 11, 2009
    346
    +3
    Thanks Hog.
    all the best
    WB.
  4. wilkybobs
    wilkybobs
    Mar 11, 2009
    346
    +3
    HI again HOG.
    just another quick question if I may, going off the frequency charts, how can you make out which channels if you loose them are high and low band, On the charts on say Lingsat you only see TP number or Horizontal or Vertical for listed channels.
    so if say its ITV that lost I can see TP44 and 49 which have one on V and one has H, checking on the meter how would I know if its Low or high band cable to check on the quattro.
    The only other entries are the 22000-5/6???
  5. wilkybobs
    wilkybobs
    Mar 11, 2009
    346
    +3
    Think ive sussed it, 9750 low ....10.600 high. look at charts to work it out.
    whats 22000 5/6??
    Wb
  6. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,170
  7. wilkybobs
    wilkybobs
    Mar 11, 2009
    346
    +3
    Thanks Kevkbuk
  8. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,538
    Redditch
    +4,185
    KU band universal lnb received frequencies
    Low Band 10.70-11.70GHz (Intermediate frequency (IF) 950-1950MHz)
    High Band 11.70-12.75Ghz (IF 1100-2150Mhz)
    From Kingofsat
    Astra 2E 10729.0Khz (10.729Mhz) V (Vertical Polarisation) 42 (Transponder Nos) DVB-S (Broadcast Standard) QPSK (Modulation) 22000 (Symbol Rate) 5/6 (Forward Error Correction)
    Therefore above is Low Band Vertical transponder
  9. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    14v lo = v low = black
    18v lo = h low = green
    14v = v hi = red
    18v = h hi = yellow
    I've added the cable colour convention, too.
