Multisession -R recording with E55
Discussion in 'Blu-ray & DVD Players & Recorders' started by davee b, Jan 16, 2005.
  1. davee b
    davee b
    Jul 19, 2001
    236
    leeds
    Hi all
    Does anybody have any experience with doing multisession recordings to dvd -R with the panny e55. i.e. does it cause a lot of disc errors when you go back to the disc and should you leave the disc in the player when you have finished a single session. Or is it a non starter . I'm archiving music tapes in SP mode so i'm currently spending 3+ hours to produce the finished product. i'd really like to do it in bits if possible. :rolleyes:
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    They should work fine. You can remove the disc in between recordings.
    Regards
    Philip
  3. AVmaster
    AVmaster
    Dec 12, 2004
    381
    Liecestershire
    Corrct. You can re-insert the disc as many times as you like and add recordings until you decide to finalise it.
  4. davee b
    davee b
    Jul 19, 2001
    236
    leeds
    Thanks a lot guys :thumbsup:
