multiroom
Discussion in 'Satellite TV, Sky TV & FreeSat' started by sv1984, Mar 25, 2006.
  1. sv1984
    sv1984
    Sep 3, 2005
    189
    19
    I have just bought his off ebay
    Sky Plus / Multiroom LNB (quad)
    What other equipment do i need so i can be able to watch sky in different rooms also different channels upstairs n downstairs...
    If i just git this and use my sky plus magic eye i have at present will that work :S
    need advise not sure what that is and bought in the hope of multi room lol
  2. stevelup
    stevelup
    Aug 13, 2002
    6,793
    Swindon
    +1,293
    You will need one normal Sky box per room in addition to your sky+ box.
    I'm assuming you've already got a Sky box so you'll need one more Sky box?
    With a Sky+ box and a normal quad LNB, the maximum number of boxes you can support is three (the sky+ needs two feeds). If you need more than Sky+ / 2 multiroom boxes, you will either need an Octo LNB or a suitable multi-output LNB switch.
    If you need to be able to watch your full Sky package in the other rooms, you will need an additional multi-room subscription per room (£10 per month per box).
    You will also need to upgrade your Sky package to Sky+ (another £10 per month unless you already subscribe to two or more premium channels).
    Steve
  3. alistaln
    alistaln
    Feb 21, 2006
    324
    46
    Reading
    +181
