Multiroom Question
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Blutony, Mar 24, 2006.
  1. Blutony
    Blutony
    Mar 14, 2006
    24
    I currently have a Multiroom sub (Sky+ & Reg Sky box). Will I be entitled to use all 3 boxes simultaneously, when Sky HD arrives, without any further sub or fitting (i.e. octo LNB & wiring) cost?
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    No. To have those three boxes you will need at least 5 cable feeds which would mean at the very least a new Octo LNB, if Sky agrees to fit one for you that is. It will also mean another multiroom sub for the third box.
  3. Pebb
    Pebb
    Dec 29, 2005
    13,152
    Eastleigh
    +829
    I have to go down the multi room route because my Dad already has his own dish installed. So I have to share his dish with my Sky HD.
  4. rpreston
    rpreston
    Can you use your Sky+ box as your second box, and dump the regular sky box in the blender ?
  5. Pebb
    Pebb
    Dec 29, 2005
    13,152
    Eastleigh
    +829
    My Dad owns a Sky+ box, but I do not. But I will be the only one in the family to own a Sky HD box.
  6. Fusewire
    Fusewire
    Jul 18, 2005
    1,617
    63
    +104
    Yeah and a HDTV a DSLR and your the first to go to the GFS :rotfl: :rotfl: :rotfl:
    If more than 4 feeds are required sky will fit an Octo LNB if you have at least 2 multiroom subscriptions, otherwise you get a quod LNB and have to live with it, if they fit the octo LNB then they will connect whatever you want to it ie Sky+ / HD / digibox etc........
  7. Pebb
    Pebb
    Dec 29, 2005
    13,152
    Eastleigh
    +829
    There is only 1 Sky + Box in the house at the moment, while only being one freeview box in the kitchen. But that should not affect it.
  8. Fusewire
    Fusewire
    Jul 18, 2005
    1,617
    63
    +104
    They will fit a quad LNB to the dish then, 2 feeds for you Dad's sky+ and two feeds for your HD box. :rolleyes:
  9. Pebb
    Pebb
    Dec 29, 2005
    13,152
    Eastleigh
    +829
    That should make the picture better for my Dad while giving me full HD goodness in 1080i, in other words its a win win for everyone in the family. But kind of a win for my Dad lol.
  10. Fusewire
    Fusewire
    Jul 18, 2005
    1,617
    63
    +104
    Why will it make the picture better for your Dad. :confused:
  11. Pebb
    Pebb
    Dec 29, 2005
    13,152
    Eastleigh
    +829
    Because he is on SD and I thought 2 feeds improves the signal.
  12. Mattk84
    Mattk84
    Feb 20, 2006
    3,547
    Weymouth,Dorset
    +135
    I currently have Sky+ with full package in living room,Sky in 1st bedroom at £10/month for full package and then a 3rd box in 2nd bedroom that just runs the free channels.
    What I would like is to have Sky HD in the living room & move Sky+ to the
    1st bedroom with the full package and add sky to a 3rd bedroom also running the full package.
    My question is(if you're still with me!) will sky do this FOC as part of a multiroom install ?
  13. Fusewire
    Fusewire
    Jul 18, 2005
    1,617
    63
    +104
    Afraid not mate, the two feeds (which should already be there if he has sky+) are so that he can record two progs at the same time, two feeds won't improve the signal as each feed is as bad / good as the other - you don't get a cummulative effect you can only view one of the feeds at any one time.
  14. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    You really have no idea, do you :rolleyes:
  15. olicuk
    olicuk
    On a similar note, what do you think is the answer to anyone currently with a Sky box (be it regular or Sky+) who wants to use it for 'freesat' rather than 'multiroom' when they get a new SkyHD box? Will Sky charge or refuse to install the additional cabling for free, or will they do it?
    Similarly, if you had Sky+ and had taken an additional feed or two from the mini-dish to say a PC with a DVB-S card, now buy SkyHD, and keep the old box for multiroom, would Sky install an OctoLNB or do they perceive the dish as their property and remove the connection to the non-Sky product?
  16. Pebb
    Pebb
    Dec 29, 2005
    13,152
    Eastleigh
    +829
    I don't care, all i care about is Sky HD when buying a set top box.
  17. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Is it just me, or does TVR_Fan have ADD or something? He seems to always be answering a different post than the one's he's quoting and never pulls together the different things he's told into a coherent picture. It's quite entertaining.
    ok, from the top, where are the 2 Sky boxes right now?
  18. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Probably depends on the installer, but to run 2 cables instead of 1 is hardly a hardship, I expect some would do it for free.
    I'm guessing but I'm sure they wouldn't give you what must be a pricey LNB just to support your habit.
  19. IanM
    IanM
    Dec 17, 2002
    160
    +5
    Does anyone know the answer to rpreston's question: "Can you use your Sky+ box as your second box, and dump the regular sky box in the blender ?"
    I currently have multiroom with a Sky+ box and a standard Sky box. I installed the quad LNB and cables for this (didn't trust the installers with the cabling) and routed two feeds to each box, although the standard box only needs one. What I'd like to do is replace the Sky+ box with the Sky HD box and the Sky box with the old Sky+ box, but I'm not sure if this is allowed.
    The FAQs seem to say that you lose your existing Sky+ box, but I'm hoping that they might be flexible on this (it's an old v1 that they'd probably dump anyway). And even if I kept the box (or bought a second hand one) then I guess that I'd effectively need two Sky+ subscriptions so they may charge yet another £10, which would certainly make me think twice.
    Any ideas?
  20. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    AFAIK you can use the SKy+ as the multiroom box and keep the recording facility without any extra cost, other than the multiroom sub. BTW which FAQs are you referring to?
  21. d.waters
    d.waters
    Aug 18, 2001
    694
    +12
    I have 2 Sky+ boxes and pay 1 multiroom subscription. I don't pay any Sky+ subscriptions because I have the Movie channels. Hope that helps!
  22. Blutony
    Blutony
    Mar 14, 2006
    24
    Would this solution work?
    If you have multiroom package now, lets say regular box & Sky+, when your hd box arrives, have fitted an octo LNB (50ukp + fitting approx) wire to a third room (not attached to a telephone) and hey presto 3 feeds for the price of two?
  23. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    If you pay for the Octo yourself and only use the third box as a freeview box then yes. If you want subscription channels on the extra box then you'll have to take out another multiroom sub. Also I think most current Octo LNBs, if they're compatible with a Sky minidish that is, are about double the price you're thinking.
  24. IanM
    IanM
    Dec 17, 2002
    160
    +5
    There was a long list of FAQs on the Sky HD site, but unfortunately I don't seem to be able to enter the site anymore, so I can't give a URL. One of the FAQs implied that the installer would take your old Sky+ box in return for the new Sky HD box. I'm hoping that that's not the case and also that I don't need to pay anything extra in order to use the Sky+ recording functionality on both boxes.
  25. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    The Sky+ box is your property, the installer can't and should not take it.
  26. speedymct
    speedymct
    Feb 14, 2006
    233
    Dorset
    +6
    Do you absolutely have to have 2 leads connected to the Sky+ Box??
    I have multiroom also & don't fancy having to lay yet another cable when I put the box up there. Doesn't bug me that much not being able to record one while watching another as it's in a spare room & only used when main room box is already being watched.
  27. Fusewire
    Fusewire
    Jul 18, 2005
    1,617
    63
    +104
    No - it will work with one lead, obviously you will lose the associated functionality because the extra lead is not there.
    But it will work as a single fed PVR with one lead. :smashin:
  28. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    No it won't. afaik.
    I think it alternates tuners for recordings or something odd. Read something about it, I'll try to dig it out if I get time. Have you tried it? I might unplug an f-plug and see what happens.
  29. Fusewire
    Fusewire
    Jul 18, 2005
    1,617
    63
    +104
    Yes - and it does. :smashin:
    You will only be able to record the channel that you are watching and you can't use the epg while recording a prog. ;)
  30. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    ooer, that's a bit odd, guess it's a channel of sorts and might be on the wrong H/V setting
