Multiroom explained??
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Les E, Mar 29, 2005.
  1. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    Can anyone tell me how Sky Multiroom works with regards to cabling from the boxes?
    I am thinking of having Sky+ in my movie room and the already existing digibox in the living room. Can I control the Sky+ options from my second digibox and how do the two boxes connect (via which inputs?)
    Cheers! :clap:
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Hi Les,
    You get two cables from the LNB to the Sky+ box and then a single cable from the LNB to the second, ordinary, digibox. Both boxes MUST be connected to the smae phone line.
    The two boxes are not connected together and operate independently of each other. You cannot control the Sky+ options from the second digibox.
    You can run RF cables from either of the boxes to other TV's in the house,
    HTH
    John
  3. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    Thanks for that, it was kinda what I had in mind but wanted to throw it out there to see what the options were.
    I have just had a new quad LNB fitted to the dish to give distribution options when I get to the install.
    I am a bit concerned with connection to the same phone line at the mo though.
    I am having issues with the line currently as we recently had broadband fitted and it is playing havoc with the phone quality and not 'always-on' with the broadband. The sky line is hard wired in with a phone extension too so I would hate to think what another input will do!! :(
  4. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Do you have the Sky box connected via a microfilter - if not, it might explain the problems you are having with broadband.
    John
  5. VKL
    VKL
    Mar 11, 2005
    53
    Kent
    HI Guys,
    If i do my own upgrade from sky normal to sky + which i dont see as a problem, could i use my old sky box as a freeview box on one of the separate outputs on the lnb?
