Multiroom activated then main box fsiled
Discussion in 'Satellite TV, Sky TV & FreeSat' started by neilybealy, Jan 11, 2012.
  1. neilybealy
    neilybealy
    Jul 9, 2001
    1,556
    48
    Kent
    +57
    Had multitoom installed in the dining room but no viewing card arrived beforehand in the post. The viewing card arrived today in the post so i activated the card using instructions on sky's website. it was left a while and i could then view subscription channels but i couldnt record or pause. i called into sky help and spoke to a helpful bloke who resolved the problem. or so i thought!
    an hour or so later in the main room i noticed my main viewing card had reverted to non hd channels and i couldn't pause, record or watch recorded programs. i called sky help again and went through various troubleshooting routines. half hour later and i still can't pause, record or watch recorded programs. i am now told the resolution is to do a sky reset which will erase all my recordings. i asked why this would resolve the problem and i was told the hard drive was corrupt! i fail to see if the hard drive is corrupt a reset isn't going to fix a corrupt disk is it? seems strange that when 1 card was activated the main card suddenly caused the hard drive to fail. i really don't want to have to reset the box erasing the drive and my months or recordings.
  2. Miss Chief
    Miss Chief
    Jun 12, 2007
    7,823
    +1,187
    What message comes up when you try to record? This is VITAL as you may not need to performa full reset.
  3. logiciel
    logiciel
    Feb 2, 2008
    53,062
    UK
    +5,738
    Fire a strong complaint right away on the form at MySky.
    Tell them to fix it immediately and to compensate you for the hassle, and for the nonsense they've been telling you.
  4. neilybealy
    neilybealy
    Jul 9, 2001
    1,556
    48
    Kent
    +57
    Live pause is not available call your broadcaster. Same as sky+ not available when I try to either record or play a recording from planner
    Already emailed the executive support team saying how ****** off I am and mrs s wants sky to be removed (she wasnt that happy when I said I was getting multitoom installed and now we potentially have lost over a year of saved recordings she is fuming)
  5. Miss Chief
    Miss Chief
    Jun 12, 2007
    7,823
    +1,187
    What's probably happened is that the Sky + subs have been removed from your previous viewing card for some reason.
  6. neilybealy
    neilybealy
    Jul 9, 2001
    1,556
    48
    Kent
    +57
    Yeah I asked the offshore bloke to double check as he was just going through the troubleshooting procedures and I told him I'm not erasing my disk as I didn't believe the disk was corrupted
  7. logiciel
    logiciel
    Feb 2, 2008
    53,062
    UK
    +5,738
    You won't lose any recordings - just don't do anything to the machine.
    It IS all about the card and Sky messing things up.
  8. neilybealy
    neilybealy
    Jul 9, 2001
    1,556
    48
    Kent
    +57
    Let's hope so :)
  9. neilybealy
    neilybealy
    Jul 9, 2001
    1,556
    48
    Kent
    +57
    I called the sky technical help team again and managed to get through to a UK person. I explained the issue and within 3 mins he found the sky + service hadn't been enabled on both cards which meant as soon as the 2nd card was paired it swapped over the sky + functionality
    Problem solved. My advice to anyone that calls and doesn't get a UK based person is hang up and redial :)
  10. logiciel
    logiciel
    Feb 2, 2008
    53,062
    UK
    +5,738
    ;):clap:
