Multiregion?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kasparaitis, Oct 11, 2004.
  1. Kasparaitis
    Kasparaitis
    If I buy a Toshiba RDXS32 OR Panny E85 thats not multiregion then does that mean it will not play copied disks?
    Normally when you copy a disk you can make the disk multiregion and so will a multiregion disk work on these recorders?
    Thanks.
  2. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    You will be able to play any copied disc as long as the copying software is set to remove MR.
  3. Kasparaitis
    Kasparaitis
    so its only worth getting multiregion if you want to play retail foreign disks.
  4. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Yes.But as it adds very little to the cost its a good idea to get one MR.You will find it very annoying when you see your favourite movie or series out on R1 or R4 years before it comes out here-if it ever does
  5. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    If you have a CC and are prepared to arder from net companies abroad, you'll save yourself a fortune buying discs from all regions. I bought my brother an x-files box set from Australia that was £30, (+£10 del), compared to £75 from Play.com, (£90 in the shops!). South Park sets from Canada for £18 del. compared to £50 from Play. Even dvd's are often £5 cheaper, and usually 4 months before it's UK release. I almost never buy uk dvd's anymore. ;) :)
    www.dvdsoon.com R1
    www.cd-wow.com R1-4
    www.dvdcrave.com R4
    www.dvdboxoffice.com R1
    All good sites to use. Also, good for games. Especially box and soon. :)
