Multiregion Rookie
Discussion in 'Blu-ray & DVD Players & Recorders' started by DPS, Apr 2, 2001.
  1. DPS
    DPS
    I have an lg3350e all my discs are region 2 but with the new multiregion handset hack i want to purchase multiregion and region 1 discs.excuse my lack of knowledge concerning this area but i would be grateful if any one could answer the following questions
    1 do you need to put the hack in each time you play a region 1 or multiregion disc.
    2 how will i know if the hack works on my player. as i dont have any multiregion discs yet.dont want to order the discs and find the handset didnt work
    any help or advice would be much abliged.
  2. Jay2000
    Jay2000
    I have the same player - once you set it to play a certain region the player stays in that state until you change it again. The easiest way to do it is to set it to R0 and this way it should play most discs. Some discs however will need to be set to the specific region they were intended for.
    If you dont have any R1 discs to test your hack, try setting the player to R1 only and then see if the player refuses to play your R2 discs. If this happens then you can assume the hack works.
    Welcome to multi-region heaven!
    Jay
    [This message has been edited by Jay2000 (edited 02-04-2001).]
  3. DPS
    DPS
    Thanks alot
