multiregion hack for a 'Durabrand DVD-1000'
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Rolly Coaster, Nov 18, 2004.
  1. Rolly Coaster
    Rolly Coaster
    Hi All
    Has anyone found a multiregion hack for a 'Durabrand DVD-1000' which is a compact little unit on sale in ASDA for just £29
    Rolly :thumbsup:
  2. phanco
    phanco
    Feb 18, 2004
    633
    Edinburgh
    +16
    I contacted Alco (who own the Durabrand brand as well as better known inthe Uk Venturer).
    They have told me that they do not manufacturer this particular model - seems a bit strange that WalMart (ASDA) would steal a brand name to me...
    Anyway, upshot is that this is not a Venturer rebadged (as mentioned in some other forums) but appears to be another manufacturer.
    So even less chance of getting a MR hack then...
  3. phanco
    phanco
    Feb 18, 2004
    633
    Edinburgh
    +16
    just got this off another forum - have not had a chace to test yet (in work) but seems to be verified -
    swith on player. open the lid. press stop on remote then enter 2379. this will give the opportunity to change region select by cursors preferably region 0 and press ok. Player will now play any region..
    If anyone can test today, let me know the results, otherwise I will post result tomorrow...
  4. dondon
    dondon
    just tested hack it works
  5. phanco
    phanco
    Feb 18, 2004
    633
    Edinburgh
    +16
    Sorry - forgot to post back - worked fine for me too !!
