MultiRegion DAV-S550 has stopped playing R1 DVD's
Discussion in 'Home Cinema Buying & Building' started by ONe111, Feb 5, 2003.
  1. ONe111
    ONe111
    Jan 2, 2003
    14
    3
    +3
    I have a DAV-S550 which was sold as a multi-region model when I purchased it (it was a software change rather than a chip). I mostly play region 2 but at the weekend wanted to play the R1 title 'Signs'. The disk came up 'can't play'. I have played R1 disks before so I put one of those in (Notting Hill) and this came up with the same message. Region 2 disks still play fine. The disk I had in the machine before trying 'Signs' was a Region 0 disk and I wondered if this had messed it up? Is there anyway to reset my machine so it knows it's multi-region again?
    Mike
