Multiregion chip or a firmware update?
Discussion in 'Blu-ray & DVD Players & Recorders' started by jedi55, May 19, 2004.
  1. jedi55
    jedi55
    Oct 29, 2003
    94
    I'm thinking of buying a region free Pioneer DVR5100. Which is better, a multiregion chip or a firmware update.
    Many thanks
  2. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    Most multiregion upgrades now are firmware upgrades or use a special remote (at least for japanese brands). If you have a standard non multiregion vanilla dvd player you often have to send it to the multiregion conversion company for the firmware to be upgraded as they won't send you the firmware disc to do it yourself because it would then be quickly copied and distributed meaning they would get far less business for upgrades. I'm not saying it isn't a chip in this case but the use of chips seems to get rarer by the day.
  3. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    The Pio 5100 is multi-region enabled using a firmware update disc, Pio players are done using an IR code.
    No one is better than the other, they both involve getting into the firmware and changing a couple of settings to enable all regions.
    HTH
  4. jedi55
    jedi55
    Oct 29, 2003
    94
    Thank you. A quick, clear and simple answer, how refreshing. So firmware is ok, thats great. I'm getting my dvd recorder from Home Cinema Heaven. Is this a good company?
  5. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,523
    Kent
    +830
    Me, I dunno mate - I don't tend to need to buy things from other AV suppliers!!! You could try doing a search and see what that pulls up
