Question Multiple zones in one large room
Discussion in 'Home Cinema Speakers' started by mccmjc, May 16, 2018.
  1. mccmjc
    mccmjc
    May 16, 2018
    3
    UK
    I have a large (well, for the UK anyway...) open plan kitchen / diner / playroom, which I'd like to have separate audio zones in. It's about 10m by 6m but with a bit of an L shape at one end.
    The main reason is so that I can listen to music in one zone whilst it is off (or at a different volume) in another.
    I have this currently set up across different rooms, but am wondering if there are limitations in doing this in a single room of this size. Would it sound bad having (for example) two sets of stereo bookshelf speakers, sited at opposite ends of the room, playing at the same time?
    Would I be better looking at ceiling speakers (this is a renovation job, so access to the ceiling for wiring is not a problem)?
    Or is this just too small to consider multiple zones?
    Thanks,
    Chris
  2. Seriously Ltd
    Seriously Ltd
    May 17, 2011
    7,789
    St Albans
    +4,203
    Hi Chris,
    We often install 4-6 speakers in this size room. Usually in ceiling or in wall. Each zone can be independently controlled. With ceiling speakers you tend not to focus on a stereo presentation due to their location and dispersion. We some times set them all to mono via an audio matrix.
    Best regards
    [email protected]
  3. mccmjc
    mccmjc
    May 16, 2018
    3
    UK
    Thanks Rich.
    So would ceiling speakers provide a better sound than a couple of pairs of bookshelf (or floorstanding)? Could I mix and match (one end of the room will have a TV, and I'm tempted to hook this up to floorstanding speakers, but the kitchen end could be ceiling)?
    Cheers,
    Chris
  4. Seriously Ltd
    Seriously Ltd
    May 17, 2011
    7,789
    St Albans
    +4,203
    In ceiling speakers placed properly can give a more even spread of sound throughout the room. They will only play down to 40-50hz so a sub woofer should be a consideration if you want more bass. They are also aesthetically more pleasing.
    You can definitely mix and match. Also consider on wall speakers for the TV. This will look again look better and frees up floor space.
    Look at speakers from KEF, Dali, Origin Acoustics, MK Sound, Definitive Technology, Stealth Acoustics and Amina Invisible speakers.
    This is a kitchen that we recently installed 4 x Origin Acoustics D68 loudspeakers.
  5. mccmjc
    mccmjc
    May 16, 2018
    3
    UK
    Thanks Rich,
    Your advice is very much appreciated!
    Chris
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,168
    The Borders
    +3,376
    I would definitely 'Mix n match' as down firing ceiling speakers are not the best option for your TV viewing and personally I don't like them much for music playback either (even background music).
    Joe
  7. Seriously Ltd
    Seriously Ltd
    May 17, 2011
    7,789
    St Albans
    +4,203
    Completely agree with you Joe re using in ceiling speakers for TV play back.
