Multiple X10 TM13 Modues and/or IR7243
Discussion in 'Home Cinema Control & Remote Controls' started by milanlad, Jun 14, 2004.
  1. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    Should having multiple TM13 modules, or a combination of TM13 and a IR7243 module, on the same house code work properly?
    Has anyone experienced any problems?
  2. KW1816
    KW1816
    Jun 14, 2002
    836
    Surrey
    +14
    Worked fine for me using TM12's and a IR7243.
    What problems are you having ?
    Kevin.
  3. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    I'm having problems diming a lamp module, either using the IR7243 or an RF Remote, when both the TM13 and IR7243 plugged in?
