Multiple tv support fromDVD/video recorder
Discussion in 'Satellite TV, Sky TV & FreeSat' started by physman, Jul 28, 2002.
  1. physman
    physman
    Not sure if this is the place to answer the question but been having problems. Not getting the signal out from my dvd/vhs combi unit from the RF out to get my splitter to feed TV via the RF normal aerial cable.
    I have the set up as follows: see link
    http://www.whatvideotv.com/articles/general/images/200105_fig4.jpg
    Assumed then that the RF cable run from my RF out to the splitter but nothing.
    ANy help appreciated.
    alan
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,277
    Manchester
    +762
    1) Your splitter (assuming it's a normal passive one) will lose you half your signal (3dB).
    Does it work going direct (like the diagram) i.e. without any splitter in line to add to your losses ?
    2) Could there be a menu to enable the RF out (UHF modulator) to work ?
    3) Have you tuned the output to a channel that the TV can see ?
    There should be a switch or menu control to generate a test signal to assist you, usually giving vertical black/white bars.
    It may be marked TSG (test signal generator).
    Chris Muriel, Manchester.
  3. physman
    physman
    hi Chris,
    hmmmm I have to admit I had not retuned the TV for the RF signal from the video recorder/DVD. Had previously been sending out to the other television via the additional RF out on the satellite different frequency!!!!
    All is working well many thanks for your thorough reply
    regards
    Alan.
