Multiple TV aerial cables
Discussion in 'Cables & Switches' started by levers, Mar 16, 2005.
  1. levers
    levers
    Mar 16, 2005
    46
    Hello, I just moved into a new house without a TV aerial. I have bought one and want to fix it in the loft. I find that there are 8 separate coax cables in the loft, each leading down to a different room in the house. I'd like to know how I can connect each cable to the same aerial because it looks like the aerial is only designed to take one cable. Thanks for any advice.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Buy an aerial amplifier with 8 outputs. Feed each cable from its own output on the amplifier.
  3. Peridot
    Peridot
    Aug 24, 2004
    2,949
    Newport, South Wales
    +292
    levers,
    Welcome to the forums :)
    As Nick says you'll need something like this.
    It will need a mains power supply, but this can be tapped off a lighting circuit if you've no socket outlets in the loft.
    If you're not comfortable with messing around with the circuits the usual extortions about consulting a qualified electrician apply :)
    ___________
    Dermot
  4. levers
    levers
    Mar 16, 2005
    46
    Excellent. Many thanks for your help.
