Multiple Projectors
Discussion in 'General Tech & Gadget Forums' started by Sparky1981PE, Jun 26, 2018.
  1. Sparky1981PE
    Sparky1981PE
    Jun 26, 2018
    2
    Denver
    We have a large meeting room that can be divided. We want two projectors in the space. Is it possible to have the projectors operate independently when the divider is closed and display the same thing when the divider is open?
  2. Sparky1981PE
    Sparky1981PE
    Jun 26, 2018
    2
    Denver
    Nada huh?
  3. tommitch
    tommitch
    Jun 2, 2016
    612
    96
    London
    +654
    Yes it is possible, but depending on your exact requirements, there are many ways to go about this, could be quite cheap, but could get expensive.
    I'd suggest seeking out an AV installer, as they can advise accordingly to meet your requirements, or budget.
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,631
    Somewhere in South Yorkshire
    +6,192
    Assuming this is current stuff, it's likely to work on HDMI. If you are happy with a manual switching solution then you could wire it all up with a HDMI True Matrix which will take several inputs and route them to two outputs, one for each projector. Thus you might have two (or more) computers or media players connected to the matrix (call them 1 & 2), and the two projectors (call them A & B). You can then use the matrix to route 1>A and 1>B, or 1>A and 2>B (or vice versa) or 2>A and 2>B; it will do so such that both displays can be on, displaying whichever source(s) you have chosen for each.
