Question Multiple profile watchlists on Amazon Prime?
zamwessell
Can you have multiple profiles with their own watchlists on Amazon Prime like you can with Netflix?
I can't seem to find any options or results.
JamesDean
Not in the same way as Netflix no. There is a kind of workaround though. If for example you had 4 people in a household and you wanted each to have their own profile then you would need to share your Prime membership with the other 3 (log in to Amazon go to your account the manage Prime membership). Each would be able to have the Prime benefits but using their own log in. Once they have this each person can log in using their own log in profile. This works if using on a laptop, Fire TV/Stick or the built in app on a tv.
cmdrmarc
Which would be fine if you could easily switch profiles without having to type in a password everytime. Using a fire tv stick remote this is about as fun as it sounds.
zamwessell
Thanks for that.I will get it all set up
JamesDean
If you have a smartphone use the Amazon remote app which makes typing much easier.
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
