Quantcast
Multiple movies on a usb for Pioneer BDP-140
valhalla
I would like to be able to put several blu-ray movies on a usb drive for playing on the Pioneer BDP-140. Does anyone know if this is possible? All I seem to be able to do is create a single AVCHD folder with a single BDMV folder under it (using those actual folder names). I have tried several different combinations of folder structures and names but none of them seem to be recognised.
Any ideas?
Glenn
HARRYSPADGE
I think you will find that it is not possible due to the way you have to name the folder structure.
I too wanted to see if this was possible on my BDP-LX55 and have also tried different ways of doing it but unless you have the BDMV folder within the AVCHD folder it just doesn't work. :(
