Multiple Monitors
Discussion in 'PC Gaming & Rigs' started by Mr_Wistles, Jul 20, 2004.
  1. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    11,795
    Essex
    +2,955
    Hello there hope someone can help. I have an Asus Radeon 9800XT/TV PRO. I have two monitors setup on it, however one is through the digital out and the other through vga out and the difference between the both is different.
    Is there a converter I can buy to do VGA to DVI ?, and where from.
  2. Marc
    Marc
    Jul 8, 2004
    11,610
    Portsmouth
    +1,081
    i got a VGA to DV converter with my graphics card, but i'm not sure if it's In or Out.. it certainly didnt do much when i used it to plug my VGA monitor into the DVI socket..
    Though i'm still not sure what you meant in your post? "The difference between the both is different" ? Do you mean the quality is a lot different between the VGA and DVI?
  3. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    11,795
    Essex
    +2,955
    Yes the qualiy is worse through vga. If I have a black screen open and drag it between the two so half is on one and the other on 2 there is a big diffrerence.
