Multiple Monitor - dvr-ms problem
Discussion in 'Desktop & Laptop Computers Forum' started by Rambles, Dec 19, 2006.
  1. Rambles
    Rambles
    Jul 14, 2004
    10,442
    167
    UK
    +2,151
    I have just installed a second monitor to my PC. I have a problem when I drag WMP11 from one screen to the other, the video goes blank on the second monitor with dvr-ms files only.
    I am using a 6800GT - DVI to main 20" monitor and VGA to second 15" monitor. Using WMP11 and nvidia purevideo decoder. All other video files work fine, divx, wmv, mpg etc... BUT if I play back a recorded tv prog from my Media Center PC I can only watch it on the main monitor, not on the secondary one :confused:
    Any ideas?
    :lease:
  2. mjn
    mjn
    May 24, 2001
    24,575
    Herts, England
    +13,389
    It is to do with overlay i think, but i don't have space on my desk for my 2nd monitor at the moment, so can't test.
  3. sinizterguy
    sinizterguy
    May 19, 2005
    1,007
    48
    +47
    A lot of videos will only be displayed on your primary monitor with native windows multi-monitor support.
    Installing a program such as UltraMon (it is essential for quality multi-monitor setups) will cure this problem.
    I have a dual screen setup (one wide, one normal) and I can move my WMP from screen to screen and it plays flawlessly, whereas before UltraMon DVDs would not play on my secondary monitor.
    I havent used DVR-MS files, so cant comment on those, but you cant lose with UltraMon, so why not give it a go.
  4. Rambles
    Rambles
    Jul 14, 2004
    10,442
    167
    UK
    +2,151
    Interestingly - this works properly under Windows Vista.
