Multiple LCD's in a Cafe
Discussion in 'LCD & LED LCD TVs Forum' started by galwaybhoy, Jun 15, 2005.
Tags:
  1. galwaybhoy
    galwaybhoy
    Hi...
    I am setting up a cafe and want to provide a service of multiple LCD screens, showing TV, DVD, etc. These LCD screens will be mounted on the wall with headphones attached so the customer can here the output.
    I was wondering if anyone had any advice on what scfeens to use, how to split up the source signal between these screens, and how to mount these on the wall while protecting them from the wandering hands of the public?
    I know this is quite alot to ask but I'm stuck at the moment..
    Cheers...
    Galwaybhoy
  2. paulfoley
    paulfoley
    Sep 17, 2003
    3,549
    Hants
    +113
    I reckon you should wallmount high e.g. near to the ceiling with those mounts that come with a 360' ball joint (v cheap on ebay BTW). This will keep greasy fingers from the screens & buttons plus you can route the power & video cables through the ceiling? You could then run the headphone cables down the walls inside "stick-on" conduit. I would use a 2 metre headphone extension plus a 2M headphone so that if a customer gets snagged up it will snap out of the extension rather than the expensive telly ?
    Good Luck !
    :smashin:
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    On a non-technical note - don't forget that you will need a Performing Rights licence for these, and if you are showing DVD's this may not be enough to avoid copyright issues. Screens in a cafe qualify as a public performance, whether you are charging to watch or not. All you need is someone from the RIAA to pop in for a cuppa, and you could get a hefty fine :eek:
  4. galwaybhoy
    galwaybhoy
    Thanks guys...that is some good advice. Do you have any advice ob what LCD screen (about 14 inch) would be the best purchase for something like this. These screens would be on all day every day for hours at an end...and would need to have TV, DVD and PC compatible connections...
    Thanks again for your time guys..
    Cheers...
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    do you want same content on all screens?
  6. TheBoingoBandit
    TheBoingoBandit
    Jul 27, 2002
    779
    28
    +26
    Avoid LCDs with poor viewing angles as these will not be watchable when looking from below.
    You might want to think about wireless infra-red headphones (as opposed to radio ones which might interfere with each other) which cost very little nowadays.
  7. galwaybhoy
    galwaybhoy
    yeah...i saw some LCD's which had really bad angles...does anyone have any suggestions for a good make and model that would be suitable for this....not too expensive though!!! :)
    Also I would be looking to be able to have different content on each of the screens at the same time....that is one of the complications about this setup I'm afraid!!
  8. TheBoingoBandit
    TheBoingoBandit
    Jul 27, 2002
    779
    28
    +26
    Try the Sharp Aquos range.
    I recently sold four of their LC13-SH1e models plus four DVD players and four pairs of headphones for a similar project.
