Multiple hdmi devices to multiple screens
Discussion in 'Cables & Switches' started by EvilZombie, Jul 17, 2015.
  1. EvilZombie
    EvilZombie
    Jul 17, 2015
    4
    4
    Rugeley
    Hi, I have two TV screens in my front room, the main "family" TV and one I use for gaming which hides away in a concealed cupboard I built. I occasionally like to run my consoles (ps4 and xboxone) through the family TV, which usually consists of me rummaging round switching hdmi cables around. Is there anything on the market that would enable me to have the two consoles connected to both tvs, and have the ability to use either TV without having to keep swapping cables around? A real first world problem I know
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
  3. EvilZombie
    EvilZombie
    Jul 17, 2015
    4
    4
    Rugeley
    Ah cool thanks for your reply, although that is a bit more than I wanted to pay! Would a hdmi splitter work in reverse? So if I connect one splitter to my ps4 to both tvs, and another one to the Xbox and again to both tvs. Does that make any sense?
  4. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Yes two splitters would also do it, but make sure they are powered ones
  5. EvilZombie
    EvilZombie
    Jul 17, 2015
    4
    4
    Rugeley
    At the risk of sounding dumb, what difference does having a powered one make? I don't plan on having it display on both screens at once if that has anything to do with it? Thanks for your swift replies
  6. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    No its more to do with that cheap ones draw power from the HDMI cable which is a bad idea, the HDMI spec doesnt allow for that
  7. EvilZombie
    EvilZombie
    Jul 17, 2015
    4
    4
    Rugeley
    Ok thanks for your help
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,933
    The Borders
    +3,575
    And ensure you understand a Switch and a Distribution Amp (Splitter) are very different devices - you can't use a Switch in reverse as a Distribution Amp.
    Joe
