Multiple hard drives with laptop
Discussion in 'Computer Components' started by markgodley, Aug 25, 2018.
  1. markgodley
    markgodley
    May 25, 2008
    6,864
    +2,469
    I have about 3-5 old internal hard drives (data) from my old desktop computer - all range from about 500gb -2tb.
    I’m looking for a cheap solutions for storing them (ideally together) and being able to connect to my laptop from time to time (mainly going to be photo storage for my photography).
    I’ve had a look on amazon and the only thing I can really find is some racks but they range from £70-150+.
    Seems expensive for a rack and power?
    Any suggestions?
    Obviously there are single enclosures, but these all need their own power supplies
  2. wormvortex
    wormvortex
    May 29, 2005
    5,768
    South of Heaven
    +443
    I use this:
    https://www.amazon.co.uk/Inateck-Do...UTF8&qid=1535202876&sr=8-9&keywords=hdd+caddy
    Obviously it's only two bay but finding a 5 bay one (if it exists, won't be cheap unless you look at the proper DAS enclosures). If you actually need all the drives connected at once I'd consider buying a large HDD and copying the files across to it. 500GB is tiny when talking about a hard drive now a days.
    This one has the benefit of offline cloning as well. Great for making 1-1 backups. Simply insert a blank drive into bay B and the current one into Bay A and hit clone. No PC needed.
  3. markgodley
    markgodley
    May 25, 2008
    6,864
    +2,469
    Awesome this looks ideal, thanks
  4. gbjbaanb
    gbjbaanb
    Dec 30, 2008
    703
    UK
    +334
    TBH I'd buy a cheap desktop PC (one with a large case) and stick all the drives in it. then I'd stick the case in the attic or back bedroom and attach to it via wifi.
  5. markgodley
    markgodley
    May 25, 2008
    6,864
    +2,469
    Wonder if i could pick your brain on this.
    I was just about to buy this, then noticed something in the comments. People are saying the clone drive in B must be bigger than in in bay A.
    Obviously i understand why - makes sense... but... say i have 2x 500gb drives and formatted the same, they could vary ever so slightly in sizing due to being different makes.
    I.e.
    Drive A 465gb remaining after format
    Drive B 462gb remaining after format
    So if i filled the drive fully in A it wouldn't clone to drive B as there isn't enough space.
    However, if i was to say fill Drive A with 440gb (leaving a little free space to be safe) worth of data then cloned, i assumed this would be Ok and the clone would work?
    Hope this makes sense!
